rolled under the truck for the 1st time holy crap!!!
rolled under the truck for the 1st time holy cow!!!
well i was at the shop doing the fuel filter and adding some more foam to the bottom seat cushion and decided to roll around under the truck and i found the clunking noise in the front end while i was under there.......................... it is the f'n right side motor mount bolt or the lack there of!!!!!!
do any of you guy's know how i can fix this asap? i know i need a new nut and bolt but what size and grade...........grade 8?
help please!!!!!!!!!
thanks in advance,
trav.
thanks in advance,
trav.
ok calmly go back and edit your title to read cow..... then go back under truck and remove remaining motor mount bolt to see what size it is.......... hold on nevermind, don't want it fallin on your head.
ClawHammer
08-03-2004 07:22 AM
