Road Trip MPG
Road Trip MPG
I recently went on a road trip from Eastern West Virginia to Detroit, Michigan to visit my sister. I pulled out of the driveway with almost a full tank. The trip was approximately 500 miles (all highway) one way.
MY concern is the fact that I am only getting barely 15MPG. I roughly travled about 430 miles before I had to fill up. I took the miles traveled on the trip odometer and divided the two, and it kept coming up with approx 14.92. I recently got my VP 44 and my lift pump replaced under warrenty (they put the intank LP in much to my dismay). Shoot I was getting better mileage before I had toe VP/LP problems.
Some things that I think maybe running against me is the fact that I have a 4:10 rear, and am pretty much stock except for air box, exhaust, and some bling bling.
A couple buddies of mine suggested that maybe my truck is not even broke in yet.
The truck only has 49,000 miles on it.
Has anyone else experiencec this with a 2001.5 or is it just me?
Thanks guys.
Thanks guys.
I get between 17 and 20 mpg if i go easy. Check the tire pressure this will make the biggest difference in your mileage i would stay at about 65 psi cold with 10 ply tires. Other than that just keep your foot out of it and you should get at leas 18
Yea i got the 4.10 gears and am getting 16-17. When i put the 315/75 Pro comps on it didnt really change me any. I guess it was a trade off between more heavy tire and less rpm's at highway speed.
my truck is stock too except for the muffler and cat is cut out
Registered
If you put on taller tire than stock it will throw off you speedometer, you are going farther than your trip gauge thinks. I don't know how much, but it would be more. I guess you could measure around a stock tire, them what your running, and do the math and see, OR take a smarty and recalabrate your speedo for the larger tires
Administrator / Scooter Bum
I'm running 235's (instead of the stock 215s) which gives me a correction factor of ~.04%.
I also have the 4.10 gear.
With the cruise control set to 64mph (~2100 rpm ) I have achieved an honest hand calculated 20.5 mpg.
'Normal' is ~18 mpg hwy.
I have similar set up except I have 3.55s. Running 285 Pro Comp ATs. Went to KC from STL a few weeks ago 19.5 MPG going & 20.5 coming back running 72 MPH @ 1900 RPMs. Calcs are based on GPS mileage.
