replace pump on HO truck with SO or HO pump
I bought my '02 HO in March 2010 with 99,875 miles. It now has 104,750 miles. Engine and fueling is all stock except for the Raptor 100 I put on it the first month I had the truck.
I imagine eventually the injector pump will go out, and when it does, I want to know what I should replace it with. For mods, I might eventually put a Juice w/ Attitude. I'll go to a 4" exhaust when I finally feel like spending money on the truck, which will happen before any fuel mods.
Thanks for the advice.
Sent from my Droid using Tapatalk
going to be based off what your goal would be with the truck what you do w/ it. daily drive tow alot, tow heavy. also either a auto or stick you get to a certain point on fueling etc. and you will need to rescue the tranny with a good clutch. my truck has completely become a 5 year bomb. I have used my HO pump the entire time replaced once. next time I will go with a SO due to my engine now with cam I would like to see higher upper fueling. I may loose alittle snap on the bottom end I dont know for sure because I have a smarty and that pulls in TQ 200rpms sooner.
but I have always been told a good set of injectors and smarty or timing box is a great combo with a HO pump.
pwrtripls1
04-05-2010 08:27 PM
schu777
09-10-2009 08:50 AM
Yukon Dodge
18
07-01-2004 10:08 AM
