Removing Oil Filter for an Oil Change?
How do you guys get the oil filter off when you change the oil? There has to be an easy way to do it. I had a hell of a time getting it off the first time I changed my own oil. Just wondering. Thanks!
take off the turbo inlet hose, and use a strap wrench from the top...
http://www.dodgeram.org/tech/dsl/filter/oil_filter.htm
Make sure you fill the new filter before you screw it on, takes 1 qt. I got my strap wrench from Snap-On, but there are others out there, Napa, Sears, etc.
Tom
Tom
Thats made by the tool company Lisle......there are better ones on the market....
I seen a really good one made by a company called Hastings.....the strap was about 3 times as wide.
Just changed my oil yesterday, usually filter spins right off with hand pressure but not this time. No strap wrench, used hammer and cold chisel from top side of filter lip. Hammered it in a clockwise motion, worked just fine.
Originally posted by AggiePhil
Man, I can't find that Hastings strap wrench to save my life. But I did find this one:
