Remove Muffler and Resonator?
Is there any advantage to taking these off and running a straight pipe? Everyone I talk to says to hack them off to make it breathe better. I don't want it to be too loud but if it improves performance and mileage then I'm all for it. Any suggestions?
if you do it, go to 4" but put in a good straight thru muffler .......i have two to eliminate the drone at cruising speed
I found that I got 100 km to a tank better and low end power was better pyro dropped 200 degrees. That is with a BAHF as well and I still have a resonator, It is louder but no drone. Yhe oped BAHF filter helps quiet the straight because you get more turbo whistle but if you lug it you get the big rig growl.
dochawken
08-28-2013 10:08 PM
jeephauler
03-24-2007 08:58 PM
