recomended lub weights for front and rear diffs
I'm changing oils and going to synthetics in the differentials what are the recomended weights for each. And in the locking rear will I need an additive?
I haul a camper I seem to remember I need a different weight for heavyer use.
Dodge calls for 90 wt in rear and 80w-90 in the front. These are for the 2500 & 3500.
Due to a lot of heavy hauling I use a high grade, synthetic, 80w-140 in both and have had excellent results. Runs quieter and I get no shiny metal shavings in the pumpkins, so I assume it penetrates everywhere!
For heavy loads, that would be my recommendation!
RJ
RJ
RJ
RJ
Check the oil you are buying. I bought Royal Purple synthetic and it claimed to already have the aditives in it for LS diffs. I suppose it is correct because it is actually working now. Got me out of a real jam and the boat launch a few weekends ago (I'm 2wd). I bought a tube of friction modifier but never added it.
mcolectd
07-08-2009 10:43 PM
modiesel
08-23-2008 09:06 PM
dodgediesel
15
03-20-2008 12:51 PM
