Rearend swap
Rearend swap
I am going to have to replace my Dana 60 pretty soon, for the 3rd time. I am thinking of going to a 70 or 80. Is a 70 a direct bolt up, or will I have to modify anything? How about going to a 80? I think my tranny is pretty harsh on the rears, and they just wear out prematurely. I am tired of collecting junk 60 rearends. If I should rebuild the 60, should I use DANA gears and the stock bearings or is the gears like the yukons, better? Thanks
Well dozer, I do have a 60, and and most 2500's I have encountered have 60's. I too thought they had 70's until I recently had to replace some bearings in the one I currently have. It seems Dodge has used both 60 & 70's in them. Back to my original questions now, thanks.
Someone has misled you then, because dodge's definitely never came with a 60 in the rear. They come with a 60 in the front, and a 70 at minimum in the rear.
They had 60s with the gassers, not the diesels.
http://dodgeram.org/tech/specs/axle/rear_axle.html
You both are right. Quit the bickering now and get back on track.
yup dodge 2500 came with a dana 70 in the rear for an automatic and a dana 80 out back for a manual. the front is a 60 in both. if yours does have a 60 out baclk, (and i'm not saying it doesnt) then someone else switched it out. did you buy the truck new? i would guess that since they came from the factory with the 70's and 80's that they should bolt right up. the u-joints might be different. not sure on that one. good luck and let us know how it works out for you.
CMAC, let me first say thanks for your service to our great country, and Godspeed back home. We did buy the truck new. This is the 3rd rearend in the truck including the original. It is now time to change it again, or will be pretty soon. The axle I have now came out of a 99 2500 diesel 4x4. I gave the tag number to a rep at Randy's R&P, he told me it was a 99 Dana 60. I also looked it up on the Dana site, and it also comes up Dana 60 there. When searching car-parts.com, you can select which axle you want, and you will find trucks with 60,70,& 80's in them. Most all of the trucks you find listed there are diesels. In fact you find a lot more available with 60's in them, than any other axle. With that said, my original question still stands, will a 70 or SRW 80 bolt right up to the springs and such. I understand the yokes could be different.Any other differences ? Are the 2 wheel drive Danas the same as the 4X4 Danas? Thanks
Here is the axle selection list for a 2000 Dodge 2500 from car-part.com
4x2, Spicer 60, 3.55 ratio
4x2, Spicer 60, 4.10 ratio
4x2, Spicer 70, 3.55 ratio
4x2, Spicer 70, 4.10 ratio
4x4, Spicer 60, 3.55 ratio
4x4, Spicer 60, 4.10 ratio
4x4, Spicer 70, 3.55 ratio
4x4, Spicer 70, 4.10 ratio
4x2, Spicer 80, 3.55 ratio
4x2, Spicer 80, 4.10 ratio
4x4, Spicer 80, 3.55 ratio
4x4, Spicer 80, 4.10 ratio
Here is search results for a 2000 2500 with dana 60 & 3:55 gears.
Description Miles Part
Grade Stock# US
Price Dealer Info Dist
mile
2001
Rear Axle
Dodge Truck 2500 Series CHECK RATIO 064049 $Call Busbee Auto Parts, Inc. USA-SC(Wagenr) E-mail 1-877-564-6307 140
2001
Rear Axle
Dodge Truck 2500 Series 3-00,RWD WE SHIP 280066 $850 Riteway Auto Salvage USA-AL(Munsford) E-mail 1-800-365-8036 199
2001
Rear Axle
Dodge Truck 2500 Series 4X4 3.55 DRUM 96,000 00017908 $675 PRP - Knox Auto Parts USA-TN(Knoxville) E-mail 1-888-242-8733 278
2001
Rear Axle
Dodge Truck 2500 Series 4X4 3.55 dana 60 full floatin 119,000 00017750 $675 PRP - Knox Auto Parts USA-TN(Knoxville) E-mail 1-888-242-8733 278
2001
Rear Axle
Dodge Truck 2500 Series 5.9D,3-08,COL-AOT,DR UM BRAKES 07K526 $650 Gagels Auto Parts USA-FL(Riverview) E-mail 1-800-537-5948 295
2001
Rear Axle
Dodge Truck 2500 Series CK 60-------SLT,5.9L,5 SP,4X4 207235 $Call Nolan England Auto Parts, Inc. USA-AL(Florence) E-mail 1-256-764-1888 / 1-800-678-1888 330
2001
Rear Axle
Dodge Truck 2500 Series 3.55 SPICER 60 DRUM BRAKE 156,000 B 07T051 $600 Tompkinsville Auto Salvage USA-KY(Tompkinsville) Request_Quote 1-888-482-0016 Request_Insurance_Quote 357
2001
Rear Axle
Dodge Truck 2500 Series 3.55 95,000 A AA0562 $Call Camargo Salvage USA-KY(Mt.-Sterling) E-mail 1-859-498-2247 / 1-800-345-1847 417
2000
Rear Axle
Dodge Truck 2500 Series 09-99,4X4 95,316 A N015P $800 Benny's Auto Parts USA-KY(Mount-Sterling) E-mail 1-800-992-3475 417
2001
Rear Axle
Dodge Truck 2500 Series 5.9 TD,AOT,4X4 99,000 A L0290 $664.19 M and M Auto Parts, Inc. USA-VA(Fredericksburg) Request_Quote 1-800-586-5492 1-540-659-2023 Request_Insurance_Quote
538
Year
Part
Model
Grade Stock# US
mile
2001
Rear Axle
2001
Rear Axle
2001
Rear Axle
2001
Rear Axle
2001
Rear Axle
2001
Rear Axle
2001
Rear Axle
2001
Rear Axle
2000
Rear Axle
2001
Rear Axle
538
Year
Part
Model
believe the duallys only had the 80 but i dont see why any of them would not bolt up direct since the housings should be the same since htye are available for the same truck. if its one for a dodge truck it should bolt up direct
Some people would look for a 2001.5 or 2002 axle so they could "upgrade" to rear disc brakes, but I don't see them to be any benefit over the rear drums, just higher cost and more maintenance is all.
TorqueFan I agree on the disc brakes. I tried that previously. I believe to get the max out of the disc brakes, you have to also change the master cylinder to one for disc brakes, and possibly the brake booster too, as they are different for discs compared to drum brakes. I too, am fairly satisfied with the drum brakes. I will look for an 80 as you suggest. Thanks for the info. I think I may just take a few measurements on a few trucks and just see for myself whats what.
