Rear End Swap
Rear End Swap
HAS ANYONE EVER SWAPPED A REAR END ON A PRE-02 TRUCK TO AN 02 TYPE WITH THE REAR DISC BRAKES? IS THERE ANY WAY TO MAKE MY BACK BRAKES APPLY MORE PRESSURE? SOMEONE SUGGESTED PUTTING A 3500 WHEEL CYLINDER IN IT. HAS ANY ONE HEARD OF THIS? IS THERE MUCH DIFFERENCE IN GOING FROM 3:55 GEARS TO 3:73 GEARS?I AM SICK OF THESE DRUM BRAKES NOT STAYING ADJUSTED & KILLING MY FRONT BRAKES.
Captain, There are kits available to swap the rear brakes over to disc. I don't have time to search for you now, but I have seen the posts where it's been done.
Check this set of posts....
https://www.dieseltruckresource.com/...rear+disc+swap
EGR I believe makes the kit.
As suggested in the posts, you may want to consider an exhaust brake.
2500CTD
10-19-2010 07:10 PM
doorguy
06-08-2007 06:19 AM
