Rear brake drum removal? 00 Dana
Hey Guys, I am trying to change the axle seals and shoes,but I don't know how to get the axle nut tab out. Please help out a non- Dana dragracer,thanks, Mark
I'm confused. Are you trying to get the drums off or the axle shaft? Because on your truck the drums are outboard and don't require the removal of the axle.
Ok, the drum is a snap. Jack up and block the rear. Remove the tires and thread at least one lug nut back on a stud at least 3 threads. Start the truck and put it in gear, give it a little throttle and slam on the brakes. The drum will fly off, thus the need for the lug nut.
If that fails, back the shoes off. If they have worn the drums signicantly, the lip that has formed will keep them from coming off.
Just use needle nose pliers to pull out the locking tab. 2-9/16" socket for the nut.
Bradleysram
01-08-2010 10:49 PM
scottmn1
11-30-2006 08:41 PM
