Question on 2001 cooling system???
As you all know, you can idle one of these trucks till the cows come home and they won't warm up enough to open the thermostat. I want to drain and flush the cooling system and put on new hoses on both the rad and heater. Would like to hear how to know system is flushed good before putting on the new stuff and refilling. Thanks gents. As you might guess, I'm not much of a wrench.
Thanks gents. As you might guess, I'm not much of a wrench.[/QUOTE]
, Take her to a Dodge Dealership !!!!!!
NA! - - - - Vacuume all of it out with a Wet Vac, and refill her after the lines are replaced!!! (Remove Thermostat First)
NA! - - - - Vacuume all of it out with a Wet Vac, and refill her after the lines are replaced!!! (Remove Thermostat First)[/QUOTE]
you crapin' me? shop vac? ha ha!
Yea!!!!!!! I was wondering when someone was going to post about these statements!!!!
But really, take her to the Dodge dealership! Expecially if you are still under warrenty!
