programmer for my 2000 cummins
I have kinda looked around for a programmer for my 24 valve cummins. It is a 2000 2wd 3/4 ton stock. I have found nothing at all as far as programmers.(lots of chips) Does any one know if such a programmer is on the market? If so, would u know the price?
thanks a lot for all your help.
Re:programmer for my 2000 cummins
Superchips has the 3705 out now. It has three settings, and will adjust the speedo for tire changes. I get $350 for them.
www.westtexasturbodiesel.com
I use a SC dieseltuner WITH my Comp box and it works great. I have seen them as low as $319 on . Keep in mind the SC Dbox does not give the grunt of the Edge products, but the mielage seems to be better. Good luck. LE
I tried the SCMT with my comp and it worked great in the lower RPM's, but it had a bad miss at high RPM's. I did not hear the engine missing in the cab, but if you had something for the exhaust to echo off of it sounded terrible. I took it off.
bigdrdge02
11-02-2009 01:17 PM
Moobesor
07-22-2008 11:05 PM
peanut
09-03-2003 03:15 PM
