Preference where to hook F/P gauge to
Old 10-31-2005 | 03:29 PM
DetroitDiesel71's Avatar
From: Dayton, NJ (temporarily while In USCG on Staten Island)
Sorry if theses seems redundent, but I am new to posting and search the threads. I bought a Dipricol F/P gauge, tapped banjo bolt. I built a -4 Aeroquip marine rated fuel hose for the run. Where do you guys prefer to read from, the bottom of F/O fiter/seperator or inlet at the inj. pump. Currently I am going to go from the inlet line to the inj. pump. Let me know. thanks. stephen
Old 10-31-2005 | 03:36 PM
farmer dave's Avatar
Inlet of the injection pump is where I have mine. This way I know that what pressure the IP is getting.
Old 10-31-2005 | 11:14 PM
AggieJustin's Avatar
Which tapped banjo do you have? If I remember correctly, the inlet to the injection pump requires a shorter bolt than the others in the system. If you try to use a regular length bolt, it will bottom out before the washers seal up.
But when I had my banjos, that is where I picked up my pressure reading. Now with the bigger lines, I pick it up on the fuel filter outlet.
Old 11-01-2005 | 12:39 AM
jrs_dodge_diesel's Avatar
Same here, thats where I have mine. I have uploaded some more photos, once they are approve you will see my tapped banjo and needle valve setup.
Nope, the IP inlet takes the same bolt as any other fitting. Wouldn't make sense to make one bolt in the system shorter than the others. Makes it more easier to work on.
Old 11-01-2005 | 08:52 AM
Okay, pics got approved. Here is the guage :
And here is the banjo bolt and needle valve :
Old 11-01-2005 | 09:47 AM
Mopar1973man's Avatar
Ok...
I'm under the Fuel filter... But works just as good... Using a isolating needle valve.
And the guage pod...
So far it's showing true and no problems.
Old 11-02-2005 | 12:10 AM
99purplecummins's Avatar
fuel going into the cab? your brave man your brave
Old 11-02-2005 | 12:13 AM
Dr. Evil's Avatar
Thats a matter of opinion
Old 11-02-2005 | 12:27 AM
we all know your brave or, well......... Evil?
Old 11-02-2005 | 12:30 AM
Dr. Evil's Avatar
Yup...
Old 11-02-2005 | 03:54 AM
Yup. I wasn't all that crazy about it when I did it but i've have tha setup for over a year and not one drop in the cab at all, not even any seepage (i would smell it then). But, on the other hand if it ever leaked then I have thet needle valve to kill the flow.
Old 11-02-2005 | 07:02 AM
Talking
well I purchased -4 aeroquip, made the line myself, haven't had a line leak yet that I have made using aeroquip, pretty reliable stuff. Crazy maybe having fuel in cab, heck I think if it did leak it would be a nice air freshener.. I wish someone would market that scent, I would buy it in a heartbeat.
Old 11-02-2005 | 09:07 PM
Motorpool's Avatar
Fuel Pressure Gage
JRS dodge diesel, I need to get myself a gage and yours looks like its mounted neat and effective, can you please tell me where I can get one like yours? sonny@defuniak.com
Thanks, Sonny
Old 11-02-2005 | 09:17 PM
Motorpool, I bought mine from Wildcat Diesel before they closed for good. Genos garage is a good source of a FP guage.
Guage is an Isspro EV (Enhanced Visibility) series guage, mechanical pressure guage 0-30 psi.
You need a tapped banjo as well to get a reading, plus a needle valve to dampen the pressure pulses from the VP44. The pressure pulses cause the FP guage to "rattle" and be annoying.
Old 11-03-2005 | 12:04 AM
have you thought about some like my father has his? easy to see, out of the way, and out of the cab
https://www.dieseltruckresource.com/...0&ppuser=20167
