Power Steering Pump Q
Getting ready to replace PS pump/rebuild vac pump/replace Hydrobooster.
Have parts on hand:
Rebuilt PS pump w/ reservoir and filter
Rebuilt Hydrobooster
Vac Pump rebuild/kit/dvd
Reading the service manual, pertaining to the section on transferring the pulley from old pump to new pump, it mentions 2 tools.
From what I can gather, the tools required just remove and press the pulley using the shaft and not the body of the pump.
Are these tools I can get at O'reilly's or Autozone, or is it something else entirely.
I'm not exactly looking forward to doing all this, but it needs done.
Thanks!
Have parts on hand:
Thanks!
if its not too late can u get the $50 bucks back on the seal kit dvd, cauz u can get the seal kit from cummins for $8.00,,,,,easy job to do just time consuming...hope your not replacing the pumps cauz of the leaks. Theres not much inside the pumps to break, just the outside frame of the ps pump can crack. the vacuum pump is as simple as they come and its pretty heavy duty.
What pully are u refering too, cauz the vac pump is gear driven, and the ps pump is attached to the vac pump. there are no pulleys to pull.
DodgeCowboy
08-28-2006 08:57 PM
amartinson
0
05-04-2003 01:55 PM
