Power steering puking fluid
Old 09-07-2006 | 03:41 PM
PHILIP@XTREME's Avatar
Been doing for a coupla weeks now. It drips a little,if any, while you are just sitting but if you turn the wheels it comes out pretty good. Its coming from the cap(which is tight). Sound like the pump?
It makes no noise and seems to work fine (until it runs out!)
Tired of putting fluid in every other day! HELP!
Old 09-07-2006 | 03:55 PM
mgstroker95's Avatar
Is the cap faulty? Does the filler neck look good?
Old 09-07-2006 | 04:05 PM
Its the stock cap,think I may try that first. The neck looks good. Just cleaned it off real good. Gonna double check but I know its coming from under the cap.
Old 09-07-2006 | 04:12 PM
Yeah I would replace the cap first. Its the cheapest!! Good luck bro
Old 09-07-2006 | 05:43 PM
nitrousn's Avatar
You have air in the system. I can run both my trucks with the cap off and they wont puke fluid out. Fill it when its cold and let it sit for a while to see if it will burp the air out. Once it cavitates the fluid gets aerated and its very hard to fill after that.
Old 09-07-2006 | 06:22 PM
Is there any method to get it out if letting it sit doesnt work? Thanks
Old 09-07-2006 | 07:01 PM
Ok after closer inspection it is definately leaking at the front of the pump(shaft?)also. So I guess its a new pump. How hard are these to put on, doesnt look to bad.
Old 09-07-2006 | 09:14 PM
BigBlue's Avatar
My PSC box used to do this. I had to replace the box cause I never could figure out where it was coming from. Never made any noises or drove bad or nothing. It would just puke fluid. I have a feeling that it was the seal that goes between the adjustment nut and the box itself.
They are easy, just messy. You'll need a pitman arm puller and a triple jointed right arm for the lines but that's it. Just unbolt and bolt back in. Oh yeah, make sure the wheels are pointed straight ahead when you do this.
BearKiller
04-12-2008 09:21 AM
Banzai Bob
07-14-2007 11:05 PM
Tommy93w350
06-26-2007 04:42 PM
clhumm
11-23-2005 05:47 PM
Commatoze
09-29-2003 05:20 PM
Quick Reply: Power steering puking fluid
