Power Steering fluid cooler
Old 03-31-2003 | 12:44 PM
perk's Avatar
Has anyone installed a cooler for the power steering fluid? When I changed teh steering box, the fluid was quite burnt. I am new to power steering systems, and don't know how it should be plumbed.
Old 03-31-2003 | 02:41 PM
TPilaske's Avatar
Re:Power Steering fluid cooler
don't know about that... but I would just put in a good synthetic and I think you should be fine... <br><br>Tony
Old 03-31-2003 | 02:56 PM
redruM Hauler's Avatar
i plumed an in line cooler to mine on my Jeep (that has full hydro steering)<br>was not hard mount the cooler cut the return line pulmb the new hoses return line is low pressure (i used std. hose clamps doubled up for safety)<br><br>dont have one on my dodge though
Old 04-01-2003 | 10:39 AM
perk's Avatar
Which line is the return out of the steering box, inboard or outboard?
Old 06-10-2003 | 11:54 PM
Mr. 45's Avatar
Did you ever install a cooler??? I put one on mine. When I changed the gearbox, the fluid was burnt and nasty. The hose i used was marked. It said power steering return hose. Yes it was actualy marked Didnt notice it untill i had it off though.
Old 06-11-2003 | 09:10 AM
Dieseldude4x4's Avatar
Probably would not be a bad idea since this fluid gets no filtering or cooling to amount to anything. I change mine out once every year and flush about three quarts of fluid through the system.
Tommy93w350
06-26-2007 04:42 PM
jimlj
05-11-2007 07:59 AM
BigBlue
06-21-2006 05:31 PM
sdgunslinger
05-10-2005 04:35 PM
Quick Reply: Power Steering fluid cooler
