Power steering brake questions
Ok I am still new to diesels. So my question is the power streering, power brake setup. So I assume they are connected in a way? Also I see the power steering pump but what drives it? The reasong is there is oil, or a oil type of fluid all over the front of the engine. It seems the power steering pump is leaking somewhere. It is low on fluid and the brakes are acting up, They dont have the same "feel", kinda touchy but the pedal semms lower than normal. Only had the truck about 6 weeks so far. still under warranty but I want an idea of whats wrong before taking it in. So I never thought about it, but do diesel draw a vacuum? or enough to run the power brakes? Thx. Just kinda lost on this part of the truck.
The vacuum pump and power steering pump are gear driven off the engine. A common problem with them is the shaft seal in the vacuum pump leaking. When making the repair, you should replace both the vacuum pump seal and o-rings. This job is not covered under the engine warranty (at least not for me). Dodge dealers used to not be able to get just the seals and would only be able to replace the entire pump ($$$). I heard that they now have the seals. Otherwise, your local Cummins shop has the parts.
That does not explain why you say your power steering fluid is low. Engine oil is what would be leaking out of the vacuum pump/power steering pump assembly. I would clean it off good, refill your levels, and check for leaks. If you look up from under the truck, you will see a chrome shaft that runs between the power steering and vacuum pumps. When they leak, you will see dripping off of that shaft.
If you want to, do a search on vacuum pumps or power steering pumps and you will get alot of info and part numbers for the repair.
Dargo
01-12-2018 07:45 PM
Dean Snow
11-14-2007 04:36 PM
DodgeCowboy
08-28-2006 08:57 PM
kry226
18
01-29-2004 03:46 AM
