Poor Fuel Mileage
Good point about winter blend. Expect to loose up to a couple mpg with winter fuel. And then dont forget that ULSD has less BTU's than LSD which in turn has lowered our fuel mileage too.
Are you using the overhead display or are you hand calculating? And even at that, are you calculating the right way? I say that because there is loads of wild fuel mileage claims and then there's been guys who will use the speedo running different size tires and divide miles by the size of the tank, not the fuel uses. So inaccuracy is ramped.
2wd
4.10 rear gear
not lifted
no extra weight
mods are exhaust / banks ram / edge juice
when i drive the truck i rarely goose it..
always go speed limit or 5 mph under.
never really sees more than 65 mph..
its all in how heavy your right foot is.
and the calculations are made manually
basing it on mileage of current fillup - mileage of last fillup / gallons of fuel added
when i tow i am getting around 14-16. 16 ft enclosed w/ 8k lbs
also add a qt of 2 stroke every fill up.
My mpg has dropped much more than usual so far this winter. We have had serious snow falls and very cold temps. I also added a 2500 pound block of concrete in the bed. I've had the chains on a dozen times already and pulled out a number of cars and trucks just so I could get in my spots. I can't complain too much. That big block of concrete really helps. Just make sure it is tied down good.
I'm down to about 14 around town which I'm drivng much more than usual. I do find that even going a bit out of the way to drive on the highway and avoid stop lights is better for mileage.
Even summer time mileage has dropped off. I got a high of 19.8 last summer driving 58 on the highway. Over 65 will drop mpg by at least 1. Generally 18-19 even.
Towing my GN car trailer in the summer I get 13-15 pretty consistantly as long as I stay on the highway. In town of course it drops due to the dang stoplights.
I'm beginning to suspect that the injectors are worn out and need replacing. Not going to do it this winter unless absolutely necessary.
Location: Then, raised central PA; Now where ever Uncle Sam sends me.
All the suggested reasons for the drop are very valid. Not sure who asked the question about more information on the truck but that would help alot. Something that would really affect fuel mileage that I didnt notice anyone touching on is valve adjustment. Do not recall seeing mileage for this vehicle but valve adjustment can really hurt fuel mileage. It about the only thing I didnt see covered. Just something else to think about.
Ben
Ben
You might do a search on here on 2nd gen "Poor Fuel Mileage". besides the points here, it seems thare are 2-3 sensors that can get dirty and cause poor mileage. Some can be cleaned, others replaced. None too expensive.
Keeping tire presuure up is good too, I think at least 60 psi all around, if not more in the front.
I did not see where you are, but if it is really cold, maybe a 10w-30 blend for the winter.
Just some thoughts!
Do you tow a lot? I know the 3.55's would help, but not sure if that is worth the time or money.
Another vote to check the valves, can't hurt a thing.
Good luck, hope you get it better!!
Just some thoughts!
You might do a search on here on 2nd gen "Poor Fuel Mileage". besides the points here, it seems thare are 2-3 sensors that can get dirty and cause poor mileage. Some can be cleaned, others replaced. None too expensive.Keeping tire presuure up is good too, I think at least 60 psi all around, if not more in the front.
Just some thoughts!
Just some thoughts!
Well let me jump onto the fire.
Left Grove okla. Dec 10 arrived in central fla (3 days later) AVERAGED 21.4
drove 65 and 70. sometimes a litttttttle over.
take it or leave it.
AkitaSumo
50
05-01-2009 07:38 AM
Happy Traveler
03-31-2003 04:52 PM
