PO122 Code
P0122 : Throttle Position Sensor/Switch A Circuit Low Input
This is a code that suggests there is an issue with the Accelerator Pedal Position Sensor which is located under the rounded black cover next to the oil fill cover. If you are not experiencing any issues, I recommend you follow the Apps reset procedure as outlined in the attached link. I also recommend you thoroughly clean the battery terminals, and cable ends, including all ground connections as well.
dieseltruckresource.com/faq/faq.php?display=faq&nr=128&catnr=7&prog=1&lang=en& onlynewfaq=1
i had a "CEL" and the codes listed here, speed sensor and voltage too high, i cleaned all my grounds and ended up installing a timbo APPS
https://www.dieseltruckresource.com/...d.php?t=296438
nasty01cummims
03-20-2009 02:02 PM
CTD NUT
04-05-2005 04:45 PM
