Plugging in. How do I tell if it is working?
Re: Plugging in. How do I tell if it is working?
Originally posted by BigBlue
I plugged my truck in last night but it still took forever for the wait to start light to go out. How can I tell if it is working or not? Thanks for the help.
Is the plug and connector clean and free of crud that might affect current flow?
I am up here in cold country and believe me i know when mine is working, if it is not plugged in it takes a long time for the light to go out, but when plugged in it cuts the wait time down by at least 75%. you should see a dramatic reduction in wait time if your block heater is working.
rob
rob
when i first plug it in ( as long as it's cold) i can here it start to "sizzle" also as described above...the wait to start is real short....mine is on a timer and runs for about 4 hours before i start the truck.
ok, i give, where's the plug?
i'm near FLA, (barely cold enough to frost)
but I drive such a short distance, i think i want to plug it in, to help it get warmer faster and keep moisture out of the motor, make sense?
i laid under it & looked under the hood, but still did not see the plug. i know i must have looked right at it
04ctd
The plug in wire is actually optional equipment on the 04's, and I really doubt a truck delivered to Florida would have one. You can get one though! Talk with the dealer. Think they run about $35 and aren't all that bad to install from what I gather.
BigBlue
Good question. Best way that I know mine is working is that with one or two cranks the beast fires right up. Sometimes I won't even get a dash light on. My fuel pressure, idle, and volts level off much more quickly as well (compared to a true cold start - not plugged in that is).
Depends on the temp and how long I have it plugged in as to how it acts. Not a real definitive answer, sorry!
Matt
BigBlue
Matt
Blue,
I plugged mine in Monday night, and Tuesday morning my wifes car had frost all over it. My windshield was defrosted halfway up, and the hood didnt have a lick of frost on it. It popped off quick too, just like it was 100 degrees outside.
Try plugging it in overnight, and in the morning pop your hood, and feel of the block. You will know. If it is not even remotely warm under there, then its not working.
Phil
Phil
Thanks man. The truck cranked on the first bump of the key, but only after waiting like 30 seconds for the light to go off. I didn't hear anything pop or sizzle last night when I plugged it in (it was plugged in for at least 8 hours).
Originally posted by YJim
Look at your electric meter before and after plugging in. Should be spinning noticably faster after. Sucks alot of juice.
