P0336, 1693 & intermittant tach
I've done some research and think I've figured it out. When the truck sits in the garage and the temp is around freezing inside, the truck sometimes does not want to start, but it will. If its really cold, -27C, the old girl fires right up. I have intermittent tachometer (only after 2 minutes of startup), it's thrown code 1693 (which is companion code?) and P0336. Which is Crankshaft position sensor? Can I get the sensor from anyplace other than the ***********? If so, any part numbers? Instructions?
Thanks and this is a great site!!!!
k9prtnr
06-03-2012 09:16 AM
