p 0237 code need major help!!!!!
so i have a 99 24valve.
water in fuel light came on which is not hooked up cause i have an airdog 2
check enging light came on.
check gauges came on and oil presurre was all the way down.
oil was good.
i ran codes. p0237
truck is running in safe mode very slow!!!
took it ot diesel mechanics.
they told me that the controller was bad and i had to buy a new one and get it re programmed by a chrysler dealer controllers are 1700 dollars!!!! please help that is outragious.....
oil was good.
i ran codes. p0237
Cummins Guru
Did they replace the boost sensor yet? If not replace it... Boost pressure will be at minimum with the key ON / engine OFF and at idle. Boost pressure should increase with the load on the engine (not higher engine rpm). The 1998 through 2000 MY trucks will display boost pressure on the DRB3 like a manual pressure gauge. Zero (0) to 20 PSI is the normal operating range. The voltage reading at 0 PSI should be about 0.5 volts. The 2001 and 2002 Trucks are calibrated to display barometric pressure. 10 to 35 PSI is the normal operating range. The BOOST PRESSURE reading at sea level should be about 14-15 PSI. The voltage reading at sea level should be about 1.0 volt. This reading will change depending on elevation above sea level and weather (barometric pressure). With the sensor connected, if the DRB displays BOOST PRESSURE is around 5-7 PSI, replace the MAP sensor. TEST: With the MAP (BOOST PRESS) sensor disconnected, the DRB3 should show zero (0) volts. With a paper clip or other suitable jumper, connect the sensor 5 volt feed to the signal wire and the DRB3 should show 5 volts. If this is okay, replace the MAP sensor. NOTE: MAP sensor operation can also be checked by pressurizing the intake system using tool #8442 or #9022.
Cummins Guru
Unplug the boost sensor, use a voltmeter and check the sensor five volt supply. If voltage is low unplug the oil pressure sensor cycle the ignition key and recheck the five volt supply to the boost sensor. If voltage is correct replace the oil pressure sensor.
Codes P0236, P0237, P0522, And P1488. Verify Oil Pressure Sensor Operation.;The engine starts and runs. May be low on power and the oil pressure gauge may fluctuate
well i took it to mechanic they tested all sensors and plugged ecm into cummins box and told me that i have a bad ecm!!!! great...... chrysler reman price 1750 screw that. i found a place on ebay for 595.. but before i buy that i took truck into my own garage and unplugged driverside battery and unplugged ecm and plugged back in. took truck for 2 min test drive no lights on now but weird wine when over 2000 rpms!!! what the heck have i done. im am going back out to let it sit and idle and see what happens.
Marks99
0
08-23-2006 06:24 PM
