overcharging,3rd time!!
Old 12-21-2004 | 05:15 PM
alottalights's Avatar
My 02 quad 5.9 H.O. is overcharging for the third time!! first time was with previous owner,had it fixed by the dealer they put in a new alternator,2 batteries and had the fenders fixed(acid and paint dont mix).After I bought it I put on about 2000 miles and the same thing happened,except for the fenders,I caught it in time. Brought it to the dealer,same thing ,new alt and batts, now its happening again,this time out of warranty, when it does it, if I pull over and come to idle it will return to normal,last night it did it and I hit the cruise button and it went back to normal,(probably a coincidence),If I kill all accesories while driving,it makes no difference,wondering if the grid could be at fault,cause the voltmeter fluctuates like when cold,but then just starts climbing,and this only happens when truck is at operating temp,also when air temp is warm.60+ or cold,30 or below,aslo does not happen all the time,I'm trying to keep track of all parameters when it happens,just hope I can get it before it cooks again, Dealer is clueless,they just want to change everything again.
Any thoughts or suggestions would be greatly appreciated.
Old 12-21-2004 | 07:55 PM
phox_mulder's Avatar
Alternator charging is controlled by the PCM.
Sounds like they never looked into it.
PCM being a computer can go bad.
phox
Old 12-21-2004 | 10:09 PM
nitrousn's Avatar
phox
or possibly a loose or poor ground for the pcm. it uses more than 1 ground.
Old 12-21-2004 | 10:54 PM
Just tonight I had someone else tell me to check the ground also,so thats my next step,I hope thats it, Thank's for the reply I'll keep you posted.
thsboss99
12-28-2017 11:19 PM
rocktoy
05-11-2009 09:48 AM
Emoo60
01-30-2009 11:59 PM
olddodgetrucks
05-16-2008 07:16 AM
dieseldave24v
02-17-2008 05:28 PM
