?? Oil Pressure sender replacment ??
Old 12-16-2005 | 02:22 AM
Smkndzl's Avatar
#4088390 is the correct part # for a oil pressure sensor , they are harder and harder to get at Cummins because of the changeover to oil press. switch.
Old 12-17-2005 | 10:41 PM
malojeer's Avatar
ordered oil press sensor from Cummins wed. morning. Mine is stuck on the high side of the dash gauge so no alarms or lights going off. Went to O' Riley's Auto Parts and bought a manual gauge made by Equus 0-100 psi and 1/8 copper line.Line ran from top of oil filter housing to gauge. Since I don't smoke removed ash tray and mounted in that slot. Some have said to install needle valve in line to smooth out flow to gauge.I did not and it works perfect.80-90 psi cold at idle goes down to 40 when hot at idle.
Old 12-19-2005 | 06:03 PM
malojeer's Avatar
my new press. sensor came in this evening. What size socket fits it and whats the best way to change it since i can't hardly see from under the hood or from under the truck>?
Old 12-19-2005 | 08:30 PM
MnTom's Avatar
I don't know for sure about yours, mine took a 1 1/16" six point extra deep socket. I bought a six point deepwell and cut the end off and welded another socket on to make it longer.
Old 12-20-2005 | 10:54 AM
RowJ's Avatar
Originally Posted by wood_n_soldier
I'm confused by something. I need to replace my oil pressure sending unit. I called cummins and they have one for much less than Dodge.
I have an Oil pressure sensor for an 01 from Dodge. Will sell if interested.
RJ
Old 12-21-2005 | 10:54 PM
malojeer's Avatar
on my 2001 CTD to change sensor you need a 1-1/4 deep socket. When ordering part from cummins be sure you have the engine # off of the black tag on the front dr side of the engine,it will start with a 5 or a 6.Just thought this might help.
Old 12-21-2005 | 11:01 PM
malojeer's Avatar
did not have to upgrade the ecm,all I did was remove the old one and install the new one,works perfectly
Royal
17
01-24-2006 04:43 PM
wcbcruzer
05-18-2005 03:26 PM
turboram
02-18-2005 10:33 AM
Quick Reply: ?? Oil Pressure sender replacment ??
