?? Oil Pressure sender replacment ??
Old 12-12-2005 | 08:11 PM
wood_n_soldier's Avatar
I'm confused by something. I need to replace my oil pressure sending unit. I called cummins and they have one for much less than Dodge. However they said that once I use thiers to replace my existing one I need to have the ECM Upgraded. - Do I really? - I've also read on here that the ECM upgrade/flash just turns off the sending unit? I don't want to replace a part to have them tell the computer to ingnore. Has anyone replaced thier with the cummins part and NOT flashed/upgraded the ECM any thing to be aware of?
Old 12-13-2005 | 11:07 AM
Timberman's Avatar
I ended up just towing the truck to the dealer and had them replace the sending unit. Don't know if they had to do anything with the computer. Less hassel, more $.
Old 12-13-2005 | 12:58 PM
MnTom's Avatar
Why didn't you just buy the sender and replace it yourself? It is not a hard job at all, only a 5 minute job on mine.
Old 12-13-2005 | 01:24 PM
redruM Hauler's Avatar
did you buy it from the dealer or cummings ?
Old 12-13-2005 | 02:06 PM
MnTom - Same question - who'd you buy the part from - apperantly you didn't need to update the ECM. My hope is that I can use the cummins part and just change it. But need to know if I'll have to upgrade the ECM as well?
Old 12-13-2005 | 07:11 PM
RAM2940's Avatar
I was told the same thing by cummins when my oil pressure sender went bad. i finally took it to the dealer and they replaced it under the cummins engine warrenty. I was out of the 3/36 warrenty.
Old 12-13-2005 | 07:38 PM
crobtex's Avatar
Be sure the reflash is not the one that makes a "psuedo" idiot light out of the gage. I changed mine, NO reflash, and every thing was back to normal.
Old 12-13-2005 | 08:26 PM
drew03's Avatar
what does the truck do when this part is bad?
Old 12-13-2005 | 08:35 PM
crobtex's Avatar
Nothing different. You just can't tell if your oil pressure is high or low....just like an idiot light.
Old 12-14-2005 | 07:35 AM
Muttface's Avatar
Go to Cummins and get the sender. The part number is 4088390NX
It costs around $70.00 and no reflash involved. This was for a 1999. Not sure if all the 24 valves use the same sender.
Old 12-14-2005 | 08:00 AM
MnTom's Avatar
Is that a new number? The Cummins part number that I found was 3408428.
Old 12-14-2005 | 07:07 PM
arcc's Avatar
Wood,
Do a search for a thread by me. I wrote a detailed message on all the problems I had when I needed to replace mine a year or two ago. It was on a 1999 too. I think it was called "Oil Pressure Question". I have not started many threads so it should not be hard to find. I think it will answer most of you questions.
Thanks,
Randy
Old 12-14-2005 | 11:47 PM
Smkndzl's Avatar
At Cummins we only sell the replacement oil press. switch now to replace all the oil press. sensor , so for it to work , you have to rewire the switch to a one wire from the two wire previously used. and the ECM has to be recalibrated to the latest Cal. so that you wont get a CEL and fault code for oil press. switch. All the new trucks are oil press. switch now rather then a oil press. sensor. the new switch is set up to trigger a fault anytime the ECM see a press. lower then 8 p.s.i if you want to maintain the oil press. sensor... I am sure they are still available out there.
Old 12-15-2005 | 07:14 AM
J BODY's Avatar
Guess I shouldn't have read this.....wife called yesterday with "no oil psi". Guess I'll be taking the truck to work today.
Old 12-16-2005 | 12:59 AM
J BODY's Avatar
For whatever it's worth I have a Mopar part number 5012991AC unit and it has the number 4088390 on the part.
Quick Reply: ?? Oil Pressure sender replacment ??
