oil pressure sender location
on my way home today my oil pressure gage went to zero and the check gage light came on. I pull over and pull oil cap off and oil was flowing good so i went on to the house. coolant temp still normal. where is the sending oval unit location. thanks
99 Dodge Quad cab
99 Dodge Quad cab
Administrator / Scooter Bum
Originally posted by crobtex
Shovelhead,
Your just too fast...............I went and found the pic, and you had it up before I got back.
Shovelhead,
I reeeeealy need to get a life away from this keyboard.
hey i just brought a manual gage tester to check for sure on the pressure for oil. i want to hook up to the port on the oil filter canister but that is hard to get with a whench or socket. any more ports i can hookup. or what is an easier way beside pulling the turbo oil line off for easy route. 99 dodge stock . also having a hard time finding sending unit. dealer want 210.00 dollars...... thanks guys
hotrod929
12-03-2009 07:10 PM
CriticalMass
07-11-2006 07:12 AM
