Oil leak at front of engine
I have some oil at the front of the engine at the base of the front cover. I assumed it was from the crankcase breather tube but today I took a closer look and it is not coming from the breather. The front cover bolts are all tight. I am not exactly sure where the oil is coming from. I will have to wash the front of the engine and perhaps use a dye to trace the leak. Cummins replaced the IP a few months ago, I wonder if the leak is related to that. Any thoughts?
OK, there are a couple of possibilities I can think of right now. If you are sure it isn't the blowby tube we will have to look at the timing case. One guy here, with a 98, DZLPWR, had his timing case leaking between the case and the block. Kind of a pain to repair. There is also the possibility of the KDP on this engine. It affected mostly 12v's, but it is my understanding that no one knows when the new timing cover went into production, they just threw the old and new together and put them on the engines. For this reason it is possible to have a KDP on a 24v, rumored as far as 2000. I did not want to take a chance on mine and killed the KDP on my 99.
It might also be the front seal, but this hardly ever goes bad, so I doubt it is the problem.
I suggest you clean it off real good then check it often if it doesn't leak right away, so you can see where it's coming from.
Chris
Chris
Also check the oil fill tube, my 95 12v was leaking at the front of the engine, turns out the oil fill tube had backed out about 4 turns, you may need to loosen the hold down bolts up in order to tighten the tube.
