oil drain plug
Re:oil drain plug
I don't know, but they are only like $8 at the *******. If you want a good replacement, Geno's Garage has a couple different designs that allow easier draining.
Re:oil drain plug
As far as I know, the 02's started using the 18x1.5mm plug. You should have the 22x1.5mm plug. I have the EZ drain plug and am very satisfied with it. I like the fact that the hose extends into the bucket preventing oil streamers from blowing around on the driveway when it gets near drained. The Finger Touch comes out too slow for me, but they are nice, and I have used one before.
Re:oil drain plug
[quote author=TPilaske link=board=4;threadid=11556;start=0#109729 date=1046362294]<br>Super Plug -- forget the factory plug!<br><br>Tony<br>[/quote]<br><br>Heck, I'd buy one just to talk to that sweet blonde they have on their website. ;D ;D ;D
Re:oil drain plug
<br>Super Plugs for the Cummins engine have been recalled and Geno's Garage has taken them off the shelf due to some incidents of the plug loosing torque and falling out of the pan, causing the loss of engine oil. The Cummins Super Plug is currently being redesigned and will be again for sale in the near future. This is according to Randy Fink and Ziggy at Super Plug.
Re:oil drain plug
[quote author=ChiefW4 link=board=4;threadid=11556;start=0#109986 date=1046404121]<br><br>Super Plugs for the Cummins engine have been recalled and Geno's Garage has taken them off the shelf due to some incidents of the plug loosing torque and falling out of the pan, causing the loss of engine oil. The Cummins Super Plug is currently being redesigned and will be again for sale in the near future. This is according to Randy Fink and Ziggy at Super Plug. <br>[/quote]<br><br>I seen that it has been re-designed. I don't have any problem with mine, other than I think it tightens itself up while I drive 'cause it's a PITA to get it off when it's time to drain. Plus the magnetic tip is so strong, it wants to stick to the side of the oil pan when you try and pull it out!
Re:oil drain plug
I installed the EZ Oil Drain Plug from Geno's last June and it has worked out fine. No problems at all!! Sure beats having oil running all over!<br><br> ;D ;D ;D
