Oil change in 6 speed tranny
Old 12-10-2002 | 09:56 PM
Turbobob's Avatar
Sorry for the noobie question but I gotta ask! Has anyone done an oil change on their NV-5600? I don't see a drain plug on tha darn thing! If you have changed it, at what mileage and how much oil does it hold? How did you drain it? Is there a synthetic lube for it? Thanks for your patience & info!!
Old 12-10-2002 | 10:03 PM
muddymess's Avatar
Re:Oil change in 6 speed tranny
just pull the pto cover. remove metal shavings on the magnetic plate down there. make sure ya got the correct wrench to remove fill plug. forget the size.<br><br>how much does it hold,,,,,i forget,but not enough. use this as an opputunity to install a pair of fast coollers for increased capacity. i will change oil b4 15,000 mi.changed the 1st time at 2000 when i installed fast coolers. i dont use synthtc. redline was recomended for the 5600 but i will research more b4 i change to synthtc
Old 12-11-2002 | 05:25 PM
amslube's Avatar
The recommended Amsoil product for the NV5600 is 5W-30 motor oil. I used the Amsoil 5W-30 HDD. Quantity is about 1 gallon. Mine has been in for almost 2 years and over 50K miles. Shifts like a dream.
Old 12-11-2002 | 06:22 PM
patriot pearl blue's Avatar
[quote author=amslube link=board=4;threadid=8160;start=0#79163 date=1039645551]<br>The recommended Amsoil product for the NV5600 is 5W-30 motor oil. I used the Amsoil 5W-30 HDD. Quantity is about 1 gallon. Mine has been in for almost 2 years and over 50K miles. Shifts like a dream.<br>[/quote]<br><br>REALLY?? did you notice a difference when you first changed the trans fliud to the synthetic?
Old 12-11-2002 | 08:04 PM
P Kennedy's Avatar
Amslube, wondering how the recommendation of 5-30W motor oil for the transmissions came forward. There is a Powershift 50W synthetic recommended for Eaton Road Ranger transmissions and this seems more like what the NV5600 has in it. The 75-90 gear oil contains high pressure compound which is designed to stick to the gear faces, this is what gums up the synchro's. Despite that my Getrag in the 91 never shifted so good as with syntec gear oil can't help but think the Powershift 50W would be better. If we digress was it not the same DC that recommended 5-30 in the Getrag in which they experienced catsrophic failures at our expense for the most part. PK
Old 12-11-2002 | 10:06 PM
amslube's Avatar
Patriot Pearl Blue,<br><br>Shifting improvement was most noticable in the cold winter months since I installed the fluid in January but shifts are smooth and sure year round.
Old 12-11-2002 | 10:18 PM
amslube's Avatar
P Kennedy,<br><br>The 5W-30 recommendation was from Amsoil Technical Services. I checked the product data sheets myself between the Texaco STF product and the Amsoil 5W-30 HDD and viscosity and other properties were very similar. I believe the straight 50W product would be too heavy especially in colder winter climates. I do know that many use a 20W-50 synthetic in the Road Ranger transmissions with good results year round.
Old 12-12-2002 | 03:35 PM
fj40charles's Avatar
AFAIK, only Texaco MTX 1874 is the ONLY DC recommended fluid for the NV5600. That is what I run. There was a thread on the other board about someone running amsoil 5w-30 oil and it shifted terribly. He drained it and it shifted smoothly with MTX.<br><br>Charles<br><br>disclaimer: not affliated with any vendor or products.
Old 12-16-2002 | 03:59 PM
TXTad's Avatar
There is a placard (well, sticker) on my 2002 NV-5600 that states that the transmission must be filled with Texaco MTX 1874 or the warranty will be void. Pretty clear what Dodge thinks is the proper lube, if you ask me.<br><br>Tad
Old 12-16-2002 | 05:05 PM
athompson's Avatar
What ever you do, DON'T fill it with engine oil. Engine oil is not designed for trannies, especially ones with synchros. I've heard that the Redline MTL helps a lot with the shifting problems many have. I don't have any shifting problems so I will probably just change mine with the Pennzoil/Quaker State Synchromesh Lube ( the new supplier since Texaco doesn't supply it anymore).
doubledodge2003
02-21-2005 10:18 AM
edwinsmith
12-27-2004 04:59 PM
bwat4
07-21-2004 06:48 PM
Sonny
02-16-2004 12:47 AM
jethroish
02-11-2003 12:19 AM
