oil capacity in NV5600
I've got conflicting information on the gear oil capacity of an NV5600 transmission, 2002 model. Time to swap the oil out. Anybody know? Thanks.
FLUID CAPACITIES
DESCRIPTION SPECIFICATION
FUEL TANK
2500 Series Club Cab and Quad Cab with 6.5' Short Box 129 L (34 gal.)*****
All 8' Long Box 132 L (35 gal.)*****
All Cab/Chassis Models 132 L (35 gal.)*****
ENGINE OIL WITH FILTER
5.9L 4.7 L (5.0 qts.)
8.0L 6.6 L (7.0 qts.)
5.9L DIESEL 10.4 L (11.0 qts.)
COOLING SYSTEM
5.9L 19 L (20 qts.)****
8.0L 24.5 L (26.0 qts.)****
5.9L DIESEL 22.7 L (24.0 qts.)****
POWER STEERING
Power steering fluid capacities are dependent on engine/chassis options as well as steering gear/cooler options. Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary cooler, these capacities may vary. Refer to 19, Steering for proper fill and bleed procedures.
AUTOMATIC TRANSMISSION
Service Fill - 46RE 3.8 L (4.0 qts.)*
O-haul Fill - 46RE 9-9.5 L (19-20 pts)*
Service Fill - 47RE 3.8 L (4.0 qts.)*
O-haul Fill - 46RE 14-16 L (29-33 pts.)*
MANUAL TRANSMISSION
NV3500 2.0 L (4.2 pts.)
NV4500 3.8 L (8.0 pts.)
NV5600 4.5 L (9.5 pts.)
TRANSFER CASE
NV241 2.18 L (4.61 pts.)
NV241 HD 3.08 L (6.51 pts.)
FRONT AXLE
Model 248-FBI (Model 60) 4.0L (8.5 pts.)
REAR AXLE
248-RBI (Model 60) 2WD 3.0 L (6.3 pts.)
248-RBI (Model 60) 4WD 3.4L (7.0 pts.)
267-RBI (Model 70) 2WD 3.3 L (7.0 pts.)
267-RBI (Model 70) 4WD 3.6L (7.5 pts.)
286-RBI (Model 80) 2WD 3.2 L (6.8 pts.)
286-RBI (Model 80) 4WD 4.8 L (10.1 pts.)
REAR AXLE—LIMITED SLIP DIFFERENTIAL
248-RBI (Model 60) 2WD 3.0 L (6.3 pts.**)
248-RBI (Model 60) 4WD 3.4 L (7.0 pts.)
267-RBI (Model 70) 2WD 3.3 L (7.0 pts.**)
267-RBI (Model 70) 4WD 3.6 L (7.5 pts.)
286-RBI (Model 80)(2WD) 3.2 L (6.8 pts.**)
286-RBI (Model 80) 4WD 4.8 L (10.1 pts.***)
*Dry fill capacity Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary cooler, these figures may vary. Refer to 21, Transmission for proper fluid fill procedure.
** Include 0.05 L (0.25 pts.) friction modifier.
*** Include 0.19 L (0.4 pts.) friction modifier.
± Include 0.1 L (0.2 pts.) friction modifier.
**** Includes 0.9L (1.0 qts.) for coolant reservoir.
*****Nominal refill capacities are shown. A variation may be observed from vehicle to vehicle due to manufacturing tolerance and refill procedure.
This is from the Dodge tech website, hope it helps......
FUEL TANK
COOLING SYSTEM
POWER STEERING
MANUAL TRANSMISSION
TRANSFER CASE
FRONT AXLE
REAR AXLE
The 5600 is a very strong transmission with one weakness -- it tends to chew up the synchronizers if you're not careful, especially if you don't treat it like a truck transmission. NVG is aware of this and changed the synchro materials in the '02my, but the recommendation I got from one of their repair consultants in Muncie was to change out the fluid every 20K miles, and use a synthetic lube of equal or greater quality than the DC recommendation. He also suggested that I install an Eaton filter assembly to tie up some of the floating synchro shavings that are inevitable with this transmission -- it's available from Geno's Garage.
And yes, I know all about the "official" DC/NVG warranty recommendations for this transmission. The guy I talked to in Muncie owns the business that rebuilds warranty returns to NVG, and NVG reps referred me to him -- so take it for what it's worth.
I changed the 5600 fluid at 5K miles for break-in, and it was pretty nasty. Installed the filter, used Redline MTF, and at 18K and 41K, the lube looked real good. Might be overkill, but there are a number of people on this forum who've had some 5600's blow the synchros and lock up -- so it's insurance to me.
I just did mine. I used 2-quarts of RedLine MTL and 2-quarts of Redline MT-90 to get the viscosity right. It sure shifts easier now. When putting in the last quart, it started to run out of the fill hole right at the end, so four quarts will do fine. The manual says 9.5 pints dry fill.
Just out of curiosity, how did you figure out using a mix would work and what difference does it make?
Maybe I will try it on mine.
1 Post
ViperSBT
05-07-2004 09:48 AM
