OD button not working!???!!!
Anyone know what to do or look for? I tried looking at all fuses and relays but no luck. I dont have a manual either.
Its a 99 3500 CTD. My light doesnt light up when I hit button on the shift lever thats on the auto steering column. And the trans doesnt do the in and out of OD thing and I need it to because Im towing alot in city and it goes into OD alot. I dont want to ruin the trans. Its been good and reliable til now!
Maybe this has happen to someone else out there??
If someone can help here I would appreciate it alot! Thks T
Hmm are you pushing it quickly, or holding it down for a couple of seconds. I know my light doesnt work(probably the bulb), but my button still works. I just have to hold it down for a few seconds when i apply/take out overdrive...have since it was new.
No it doesnt work at all. I know because no light and it doesnt fo in or out of OD! Frustrating a bit because around town or slow highway traffic it sucks!!!
If anyone else knows pls let meknow!
Thks!
Thks!
![Duhh](https://www.dieseltruckresource.com/forums/images/smilies/new1/duhhh.gif)
Lubricate cap
Mine was not working all the time and had to hold switch in hard to work at all so I took the cap off the end of the shift handle a sprayed it with WD40 and it works fine. Twogun
Wow OK! I think I will check out the cap end of the shifter and see if thats it.
I hope I dont have to open the trans pan, fluid change and filter. It was done 6 months ago.
THks T
THks T
![Shocked](https://www.dieseltruckresource.com/forums/images/smilies/shocked.gif)
Tedonlin150
02-04-2010 11:37 AM
can17
11-10-2008 02:53 PM
SilverRam3500
02-25-2007 08:24 PM
