not starting right
not starting right
hey guys I could use some help here please. my truck is not wanting to start like normal i need to crank on it several times 2 or 3 for several seconds be for it wants to start my lift pump is a fass and its running 14 psi wot 16 at idle. i just bought this truck 1month ago with 64,000 miles on it . and i just installed the fass and fp gauge last week could this be the problem? or something else!
It could be an air leak in the system. I had a hard start problem after i did some work on my system, it ended up being a loose fitting and it was loosing its prime sitting over night. so double check all the connections to see it you got a small leak.
Ok i checked and rechecked all fitting are tight. the thing that has me stumped is that half the time it starts perfect this evening i went out and started it 4 x and all 4 x it fired the 5th time i had to crank on it for 10 sec. seem to be no pattern it started fine almost all day but then it takes for ever?
Michigan Ram
08-24-2011 11:25 PM
Common
08-24-2006 06:31 PM
