Not starting like it used to
would bumping your fuel pump and not starting the truck and letting it attempt to prime and push fuel. if this helps and it starts right up like said before somewhere is a return to tank air leak. I had same problem in past parking nose up over night and it wouldnt start only after 4-5 seconds. my problem was the connection hose in the back of my fuel filter housing. replaced my fuel line from fass to stock fuel filter and was good.
I have tried bumping the fuel pump (the pump runs without the engine running) with the same results. So going off this we can eliminate the fuel leak right?
I just checked the codes again and it does say
P PCU
P 0500
P1694
P ECU
P 1693
Weather they are good codes or not, I don't know, but that is what is says. Any more thoughts?
P PCU
P 0500
P1694
P ECU
P 1693
I can't find my list I had for them. It was a sticky on here some place but can't seem to find it either. You might call a dealer. On occassion you will find one that will tell definition.
K, so this has been going on since October of last year - still with no good results. I have taken it into my local shop and they replaced
1 - intake gasket
2 - banjo washers
2 - large banjo washers
1 - VP44 overflow valve
6 - fuel tube O-rings
Something I recently discovered is when I park it facing downhill, it has a hard time starting (when it does fire, it coughs and smokes kind of a gray smoke for a couple of minutes). If I park it facing uphill, it fires right up. I am talking a difference of parking it in my garage forward or backward. My garage floor only slopes about 2" from the front to the back? Me as well as my local diesel repair shop is baffled. Any ideas?
1 - intake gasket
2 - banjo washers
P PCU
P 0500
P1694
P ECU
P 1693
P PCU
P 0500
P1694
P ECU
P 1693
Don't jump to expensive conclusions until you have good information.
Hard starts facing down hill indicates a fuel leak. Check fittings at VP, injectors, T fitting on return line at back of head & lines back to tank. It could also be as simple as a leak at your fuel filter O ring if you have the stock LP.
Junk Man -
It is a 2002. Thanks for the other leads, I will check them. It has been parked in the garage it's whole life with not a drop underneath it. I have a FASS pump. Again, thanks for your your help.
Ok so when I took it back to the shop (for the 3rd time now ) I printed this out
I laid it on the seat for them to look at. They did this as well as put a new filter on my FASS, as well as all the other things previously listed. Guess what, it still does the same thing. When I went to pick it up the mechanic said all their mechanics have scratched their heads have done all they could think of and it still doesn't start like it should.
Anyone else?
Anyone else?
0500 is no input from vehicle speed sensor which on a 00 is on the rear diff. I'd change that, clear codes & see what happens. Rent a scanner from the chain stores. In some places, you can borrow, scan & clear. In others, the store won't let you clear on premises - then you have to rent & return.
1693 is companion code meaning that codes are set in PCM and ECM. Let's ignore for now.
1694 is fault in companion module ie PCM not communicating with ECM (I think).
If I'm reading right, 0500 would set the engine light and set a code in both PCM & ECM. This would also set the 1693. If there is a hiccup communicating between between the ECM/PCM, you'll also get the 1694.
Apparently the pros are guessing. Are they also charging to swap parts?
I will have to get them cleared next time I am in town.
So...Not sure what you have done. Have you changed the speed sensor? That is where I'd start because of the 500 code and because it is cheap & easy. Clear the codes & report back if not fixed.
Next I'd put a wrench on all of the fittings of the fuel system. The stock fuel filter is held on with 2 bolts & moves easily so you can get to the T fitting on the head. Follow & snug the lines back to the tank starting at the VP.
