normal oil pressure
normal oil pressure
my oil pressure gauge stays at about 60psi when the truck is running even at
idle. Is this normal my cousins truck runs at about 35-40psi at idle and climbs to 55psi while cruising but her truck is an S.O.
It basically turns your perfectly functional oil press. gauge into a dummy light. In other works, when the oil pressure fluctuates (reving up, settling back down to idle, etc.) the gauge will read the same pressure no matter what. Only when the pressure drops down to nothing will the gauge (along with the dummy light) that there is a pressure problem.
reason for reflash is dealer likes an easy fix for easy $$$$. if u live in cold climate this is normal, pressure can go as high as 100psi in cold. thats the reason for a heavy duty oil filter like the fleetgaurd.
GlennRMK
05-24-2007 10:46 PM
Ripper01
04-11-2006 09:10 PM
DFD536
02-07-2005 09:59 AM
dieselpowerrules
07-27-2003 10:52 PM
