No Tach or Overdrive
I've got a 98.5 24 valve that the tach quits about 10 seconds after I start it. The truck is put into limp mode I guess due to the tach not working and it wont shift into overdrive either. I checked the codes and it came up with a P0336 code(Crankshaft Position Sensor Performance) so I changed the CKP out and still no change. Anyone have any suggestions of what could be wrong?
Didn't the 98.5 have both the Crankshaft Position Sensor and Camshaft Position Sensor?
I know the later 24 valves got rid of one of them, merging their functions into the remaining one.
(I always forget which one went away though)
phox
phox
It does have both of them. I've changed them both out and still nothing has changed.
next step is to check the wiring. You have to get a wiring diagram and check the connections to the computer and crank sensor, also the pin's to make sure there bent to make the connection. Would this thing even run with out a crank signel? Mybe its the connection between the ECM and PCM, or bad PCM. Stupied dodge product anyways. Three computer's to make it go down the road!!!!
ECM, PMC, Modual on the injector pump, Body control Modual, AbS Modual, Airbage Modual......what to go bad next!!!!
u have to make sure u didn't over/under torque the ckp sensor nut too far or too close for the mag pickup to function correctly the oring is also acting as a spacer so make sure it isnt crushed
I've checked that out several times and still no change. Is there any other things that might cause this problem? Is there any chance that the tone ring could be loose or something?
I've tried two new sensors and even one off my buddies truck that is identical to this one and still didn't help. I guess i need to drop the pan and check the tone ring and make sure it's still tight and not missing any teeth. Thanks!
Beefdoc
06-15-2012 09:54 AM
banks-powered
01-08-2008 05:49 PM
Racing_Joe66
20
09-22-2007 08:51 PM
72demon440
04-27-2007 10:45 PM
