no start conditoin?? 4 error codes? help!
Old 02-08-2006 | 04:13 PM
sandpuller2004's Avatar
truck left me stranded. got a ride back to work. have good fuel pressure, at least when it would start.
went to AAA to pay for registration. came out and no start.
has the following 4 codes
P1689
P1690
P0336
P1693
any suggestions?
Old 02-08-2006 | 06:14 PM
RAM2940's Avatar
The p0336 is the crank shaft position sensor. Not positive but i think this can keep the truck from starting. Good luck
Old 02-13-2006 | 11:30 AM
Update
well i had 4 codes being thrown, one being the 0336.
Removed replaced the crank sensor and all of the errors went away.
truck is happy! Only question is this is the 3rd crank sensor in this truck in 100k miles. What other variables could case a crank sensor to go bad?
has anyone seen a hypertech tuner cause parts to go bad? i was getting alot of communication errors as well.
Old 02-13-2006 | 12:30 PM
amh's Avatar
amh
Here are the 4 codes:
P1689-NO COMMUNICATION BETWEEN ECM & INJECTION PUMP MODULE
P1690-CRANKSHAFT POSITION (CKP) SENSOR DOES NOT AGREE WITH ECM CKP
P0336-CRANKSHAFT POSITION (CKP) SENSOR SIGNAL
P1693-DIAGNOSTIC TROUBLE CODE (DTC) CLEARED IN COMPANION ENGINE CONTROLLER (JTEC) MODULE
Two have to do with crankshaft sensor and one with VP44, I would start on the crankshaft sensor first. (hoping its just the CKP and not the VP44).
good luck
Old 02-13-2006 | 02:54 PM
RAM2940's Avatar
The only thing i could think of is that it might be installed to far into the socket and got nicked by the crank. Or vibrations, or just plain bad luck with the sensors.
grunthmc
06-05-2012 11:17 PM
exwrestler
02-05-2010 10:34 AM
newtododge
08-16-2005 12:13 AM
StillPlowN
02-15-2003 07:04 PM
