no reverse update
no reverse update
well, i pulled the pan this after noon and discovered broken reverse/1st brake bands in the pan.so i started to remove drive shafts and transfer case.
a question though;how do you separate the transfer case from the transmission/i removed the six nuts that hold them together,or is it easier to remove them as a unit and separate them once they are out.
i will look at it again in the morning.
thanks.
brett 2002 2500 quad cab 4x4
thanks.
thanks.
thanks.
Since the band is toast, plan on a new drum and 4th gear support. Although you may get lucky, you'll just have to wait until it's out.
Did this have a shift kit in it by chance? I have seen 3 other trucks with your previous symptoms, all with shift kits.
Dave
Shift kits that raise line pressure will kill L/R band especially if adjustment gets on sloppy side. Make sure the spring on L/R servo is not solid.
i believe it is a valve body.the transmission is stock.i posted a question the other day about putting a 48re in place of my 47re.do you guys no what this would entail?
brett
brett
Hummin Cummins
06-05-2003 11:27 PM
TX Ram
04-11-2003 05:56 PM
