no power brakes or steering?
Vendor - Former Vendor
My mom went out to start her truck this morning (02 auto) and it had no assist brakes or steering. I checked the pump and it seemed like there was too much hydraulic fluid. I check it at every oil change and have never overfilled it. It drove fine last night, but this morning it doesnt work. Any ideas? Thanks in advance, -Evan
Don't know if got cold enough in AK for PS fluid toqujit flowing. If fluid is brown, would be good time to change fluid.
REcomend MOPAR PS fluid.
Believe have had problem with ATF + 4 in sub freezing temps. Aftermarket syn fluid might work also.
Another thought! A diesel doesn't flare when it starts up. Vanes in PS pump sometimes need to be centrifugal force to operate. Just rev the engine up to say 1500 RPM and see if starts working.
I will try revving it, but the fluid looks fine and it only got down to about 40 degrees last night! It was much colder a few weeks ago and it was fine then. thanks, -evan
i had same problem (sounds like). the conventional ps fluid becomes too thick at cold temps, thus creating too much pressure and squeezing thru the seal on the cap resulting fluid loss. i flushed the system and replaced with a synthetic fluid and has been great ever since!
happened to stepdad's pickup and i did it too!
This happened to me the other night after leaving it parked at for a month - maybe the fluid thing woulda prevented it from ever occurring in the first place, but revving it to 1500 rpm as dozer recommended freed up the steering & brakes right nicely...
THANKS dozer...!
THANKS dozer...!
I had the same thing happen to but i put a new power steering pump on it and a hydraulic brake booster and it still did not fix it can you help thank you my truck is a 1999 Dodge 3/4 ton 4+4
Last edited by FIREBUG13; 11-15-2008 at 07:54 PM. Reason: need to and more to my post
have any of you guys ever heard of Lucus oil products ? I had this issue occure several years ago . If the fluid appears un contaminated color wise and doesent smell burnt add the lucas ps additive saved my pump and has worked great since .
