Newbie Needs Help!!!!
Old 04-23-2007 | 01:20 PM
redrum323's Avatar
I bought my truck last month and really have enjoyed it. I do have one problem, when I'm cruising at 40 mph, the truck starts wanting to upshift then downshift.... Is this something simple or should I take it to the dealer?
Old 04-23-2007 | 01:29 PM
Dinner's Avatar
That's about when your torque converter is engaging, then disengaging. "hunting" for where it wants to be. Some people have noticed a change after cleaning off all the grounds for the electrical, as well as some new batteries. There is other tips as well out there too though.
Old 04-23-2007 | 01:37 PM
redrum323's Avatar
Thanks! I'm still new at this. I graduated from a Dodge 1500 to the 3500. I am learning it's a whole new world.
Old 04-23-2007 | 02:50 PM
Dinner's Avatar
What year is your 3500, etc. If you can, would be great help for everyone if you fill out your signature. That way we know how many km, what is all done to the truck, what engine is in your truck, etc
Old 04-24-2007 | 02:43 AM
redrum323's Avatar
Okay Dinner, Thanks for the Info. I tried to fill out the signature with as much info as I could. Hope it helps. Thanks again
Old 04-24-2007 | 03:50 PM
b4wheeler's Avatar
There are a bunch of little tricks to stop the trans from hunting....
Clean all batter connections and all ground connections.
I think there is also a trick to isolate the alternator cable with tin foil.
There is also a kit out to fix the 3-4 hunt.....
I have seen line pressure adjustments fix 1-2 hunts, this might work for the 3-4, but that would be last resort.
Old 04-24-2007 | 04:21 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
I've done all of the above, but still had the same problem; just not as often. But I've learned that while cruising under 50 mph I've just pushed that little magic button on the end of the shifter. That way when under 50 mph I'm not using the overdrive, problem solved. I've also noticed, maybe it's my imagination, that with the O/D off the tranny seems to upshift more smoothly and solidly...........
Old 04-24-2007 | 04:38 PM
crobtex's Avatar
Some folks have improved their shifting problem by adjusting and/or recalibrating the APPS.
Instructions here and here.
Old 04-24-2007 | 04:39 PM
OUTDOORSMAN's Avatar
If I am not running atleast 50 mph I run with the od off. Without having a muffler, sometimes I run it right up to 60 if I am feeling like it.
Old 04-25-2007 | 12:38 PM
redrum323's Avatar
Hey Dinner,
Thanks for the tip. Cleaned all the battery connections and that did the trick. Good thing to, when I went to clean them, I found the right side battery connectors were loose. I cleaned them and tightened everything back up. It went through the gears better then when I first bought it. Thanks again! Thanks to everyone else for their input. I feel better there is a site like this one.
Old 04-25-2007 | 01:39 PM
Dinner's Avatar
Originally Posted by redrum323
Hey Dinner,
Glad to hear a simple little trick like that helped out. Hopefully it'll stay running smooth for awhile
FRAMEMAN
03-31-2008 10:26 AM
michaelsmalley
10-15-2006 02:13 PM
cowboy717
15
08-22-2006 05:41 PM
Kevco
01-20-2006 10:17 PM
wmwise
07-13-2005 08:10 AM
Quick Reply: Newbie Needs Help!!!!
