Newb Questions - '99 3500 DRW
Hi all.....bought my '99 3500 DRW 4x4 about 4-5 months ago & have some questions. Truck has 330,000 KM (not sure in miles) on it...
Now the fuel mileage just began to suffer real bad. Not sure on the fuel pressure, where do i find a port to test it?
Power seems a little low too.....towing 8,000-10,000lbs in a dump trailer, seems to struggle.
Valves sound a little noisy, even for a diesel @ cruise. Should they need adjustment, i dont think its ever been done.
Any links to COST EFFECTIVE EGT/fp guages? I already have a money pit, and its in the form of an '81 Z28 TT. Also would like to know what CHIP/PROGRAMMER would be the best BANG for the buck in terms of mileage/torque. This truck is used mainly for hauling 95% of the time.
Any help is appreciated.
BTW, already checked for codes (on/off, on/off, on) and found nothing.
Welcome to DTR!
If you will fill out your other info under user CP we'l know a little more about your truck. auto..5 spd...etc
* The key on/off does not work on at '99.
* If your pulling that much weight, you definately need to get gages. At least FP, pyro and trans temp if it's an auto. Gages are not real expensive when you figure how much money they can save you. Check some of the DTR sponsers for prices.
* Fuel pump or injector pump or dirty fuel filter are the firsrt things I would check that could cause low power.
* I don't know about the valve adjustment.
Originally Posted by Stroked-Z
oh ok.....any suggestions on how i do it then>?
if the Check Engine Light isn't on, Autozone might not do it though.
phox
yup its an automatic BTW.....
I have not changed the fuel filter yet......do i have to bleed the system or anything after i change it? Or just leave the key on for a few secs before starting it?
If your pulling that much weight with an auto, most would advise a tranny temp gage.
I have th Edge EZ to help towing. One of the sponsers, Quadzilla, has a new one that I believe is just for towing. Check his ad: https://www.dieseltruckresource.com/...ad.php?t=76985
I believe they switch to winterized diesel around this time. They did in the Edmonton, Alberta area. My mileage is down about 12% from since I bought it in August, and my driving habits haven't changed.
Ok guys....can anyone tell me where i can tap in to to get the f/p reading?
Also, what will i need to do it (besides tools). Do i need any special fittings, etc?
There are numerous threads in the "Performance and accesories" forum regarding fuel pressure installations.
Just remember, 1998-1999 installs are different than 2000-2002.
phox
sqrl$$
03-01-2010 09:18 AM
rconkin
05-04-2009 01:33 AM
89dieselkong
04-05-2009 05:20 PM
dragginlx
15
03-09-2007 11:32 AM
roadranger
14
04-14-2005 05:35 AM
