new user need help,
new user need help,
Owner of a dodge 2500, truck running great, shut it down, went to crank after about 15 min hard to start, but did and ran very rough, as air in system, settled down and idled smooth, but when got over 12,000 rpms, would spit and shutter,
no power, but cranks fine now but will not go over 12,000 rpms.
What codes is it showing?
Do the code thing and turn the ignition on and off (without starting the engine) 3 times leaving it on the 3rd time and read the numbers displayed in the odometer.
I would put a scanner on it borrowed from a parts store. Key frequently doesn't mean squat. Next, check for leaks in the fuel system. Look at the hard lines and the head. Check the over flow lines and T fitting on the head. Follow the fuel lines back to the tank. If no leaks, loosen & tighten any joints that are threaded. Do you have stock LP?
LightningMqueen
12-01-2006 04:42 AM
