new map sensor?
new map sensor?
my 2001 truck just feels under powered and like it almost just falls on its fae after i try to get on the skinny pedle hard and then shift. like it is boggin down or something and then once some time passes and it builds boost it will go and in the next geear it will do the same thing. and it has a P0234 code. which i guess is an engine over boost code. could it be my map sensor that needs replacing?
well i dont have time for the sig right now. but my truck has an edge comp. air intake, straight piped, boost elbow, and the guy i bought it from said it had some injectors worth 80 in it, but i put everything else on. and the the little stuff like gauges , pac brake, blah blah blah. and before this problem i was makeing right about 32 * 33 ish PSI and not it is a consitant 20 when i get on it which if i am not mistaken is stock. and i have tested my comp box, and it is not that. i know this is a long reply, but please help me. i want my truck to be faster again. im tired of it driving this way
scottboy69358
07-04-2013 02:05 AM
Moobesor
02-23-2008 09:57 AM
Booost Almighty
01-01-2006 01:41 PM
