New lift pump/filter, low psi.
Truck is 98.5 2wd dually auto. Just replaced in-tank lift pump with brand new unit from mopar. New filter. Also replaced plastic lines at the tank due to the feed line being kinked. Running between 8-10 psi at idle and 4-5 psi loaded. To me this seems low, any ideas?
Yes, replace as many of the banjo fittings as possible. They are a major restriction even on a 100% stock truck. The big line or relocate kit from Geno's Garage will make a big difference. Before the kit I had 6 to 8psi at idle, 13 psi after. Full throttle came in at 4 before and 12 after.
the flow is adequate for a stock engine
The engine mounted pump is a pusher style also - just some dum _zz engineer put it in the wrong place
If his truck has had the factory relocation warranty repair done previously, it has the in tank pump.
Mine was just done last August and holds a steady 10 psi. The Dodge tech says this is enough. After the warranty expires I'm going to upgrade to an aftermarket system.
Kurt
Kurt
38 Cigarette
16
08-28-2015 11:27 PM
nrussell
07-23-2008 08:58 PM
Tommy93w350
08-07-2007 12:15 PM
Dave88LX
15
09-04-2006 09:30 PM
ckennedy
09-29-2004 05:06 PM
