New Fuel Pump in the tank
I just paid a grand to have Dodge put the fuel pump in the tank ( some of the costs of living in Hawaii and having a truck in California)
My question is will the new fuel pump change in any way the priming of the fuel filter when I change it or do I just keep doing it the same way ? (by filling the canister with fuel then cycling the pump several times before start up)
I change it once when I get to California each year and once when I head hometo Kauai
Ouch! A $1,000 for a fuel pump? For $400 you could have ended the LP problems and bought a more reliable FASS II after market pump. Installation is about 2 hours.
I drain, wipe clean, then fill my fuel canister 3/4 full with fresh clean fuel then screw on the filter top with the filter and it does overflow just a little.
I'll then bump the starter to cycle the pump 3 times then start the motor....it should still work with your intank.
What's yer lift pump fuel pressure?
P-Kid, Not trying to hijack your thread. I had mine done to.
The dealer replaced my stock LP with a tank mounted pump last Friday. After they ran a VP volume test (and failed), my truck is still there to have the VP replaced Tuesday (both under warranty with 90k miles)
I'm reading on different boards that this may not be the best preventive fix for the LPs by moving them to the tank, But, not much choice if using dealer and DC warranty......
Does anyone use a LP in the "old" oem location (where the dealer now puts a block) in tandem with the dealer relocated tank pump???
When their are 3,600 miles of Pacific between you and your truck you just pay! If I was there I would have done it myself. The truck was surging and if I hooked up the EZ chip it went nuts shuddering ( pulling or not ) So I bought the service advisors line and got the pump. Now I go to Abbotsford Canada on July 12th to get the new DTT transmission they have built for me ( $ 4,000 ) and I should be ready to haul?
FWIW,
I had a long talk with the Service Manager today at the dealership. He said the current consensus with DC is transfer pump flow rate, not pressure is what the VP needs to survive. (He says it's written in a TSB)
He says that the in-tank pumps provides adequate rate to feed the injection pump. Claims he has seen one local xfer pump failure after the DC in-tank modifications have been made. Has anyone read the TSB?
Interesting topic. I went to replace my dads lift pump in his 99 2500 CTD and the dealer had the kit for 500 bux plus labor to install it in the tank.
I called up a cummins shop in town and found the original for 185 including tax and installed it myself in the stock location.
I hope I made the right decision!!
Mike M
06-05-2006 11:38 AM
ddestruel
03-26-2006 01:54 AM
