Need new PCM (no alternator)
Old 11-27-2007 | 11:20 PM
ChrisM55's Avatar
Well, after exhausting all my options, it looks like I need a new PCM for my truck.
Is this something where I can get a used one from a junk yard or do I need a brand new one from the ***********?? Can I order it online?? Maybe Dave Smith motors?? Anyother options cheap??
Thanks guys
Chris
Old 11-28-2007 | 07:27 PM
mini14's Avatar
u can wire in an external voltage regulator...do a search on that topic u will find much info...
Old 11-28-2007 | 11:02 PM
ChrisM55's Avatar
Found the info from Infidel. Next question is can I run a jumper to test my theory that it is the PCM and not the alternator. If so, which wire do I jump to on the alt plug
Chris
Old 11-29-2007 | 05:09 PM
ChrisM55's Avatar
ok, I installed the external VR this afternoon and thank God, I am getting charge now. It is going up and hovering around 14 volt now though. Is this a bit too high??? Mal alternator is getting quite warm also, but that could be because of the hi draw from tha mostly dead batteries
Chris
Old 11-29-2007 | 11:24 PM
nickg's Avatar
Is the VR adjustable? 14.75V is the MAX it should ever put out. alternators do get hot so thats normal.
Old 11-29-2007 | 11:48 PM
ChrisM55's Avatar
no it is not adjustable. Runs at low 14 all the time. 14.05 14.08 never over 14.1
Chris
Old 11-30-2007 | 12:19 AM
johnh's Avatar
try this.......................
http://www.ecm-ecu-online.com/dodge_part_numbers.html
Old 11-30-2007 | 08:58 PM
WestTN's Avatar
Where are you? VR's are temperature sensitive to account for battery chemistry versus temperature. Colder temps mean higher voltage to keep the batteries charged. Voltage output ranges from ~14.4 in arctic conditions to ~13.7 in summer desert conditions.
Old 11-30-2007 | 09:16 PM
ChrisM55's Avatar
I am in Reno and it is cold here right now!! Might be why it reads higher now
Chris
Old 12-01-2007 | 05:53 AM
dodgeguy71's Avatar
14 volts is fine. I've seen stuff up to 14.5 volts and never any problems. It's when they start putting out 15.5 or 18 volts as I have seen on one.
moparman13045
07-10-2013 12:48 PM
5.9Excursion
03-13-2008 07:08 AM
Big Perm
12-18-2007 08:44 PM
Cam73
02-06-2007 10:07 AM
arroyojim
15
04-15-2006 03:51 PM
Quick Reply: Need new PCM (no alternator)
