need help with mystery switch
Old 01-05-2008 | 12:06 AM
Mykey's Avatar
i'm new here this is my first post, i've done the thing just like it says on here and it wont work, i have a 01 2500 i'm also new to the diesel world, so i dont know a lot any imput would help, thanks
Old 01-05-2008 | 12:15 AM
Russ Roth's Avatar
All it does is ground the wire. Sounds like you probably have the wrong wire or else a bad ground. What color code is the wire you used?
Old 01-05-2008 | 06:33 AM
91rangerturbo's Avatar
What switch is this? A TC over ride switch? There is not enough info in the post. Could you please explain a little more or even take a picture if needed.
Old 01-05-2008 | 09:20 AM
V Baker's Avatar
Did you try these instructions?http://www.tstproducts.com/Torque%20...p%20Switch.pdf
Old 01-05-2008 | 10:14 AM
Mykey's Avatar
I did the thing just like on the tst web site, I've checked my ground I've checked my switch the wire is B11 orange with black chaser I've doubled checked that and nothing, is there something that could be wrong with the converter that is keeping it from locking up?
Old 01-05-2008 | 03:32 PM
chainzaw's Avatar
Did you remove the trans relay and install the jumper wire correctly? From what i gather form that article is, if you don't add that 12 volt jumper the switch won't work. And you haven't mentioned if you have done it yet.
Old 01-05-2008 | 03:53 PM
Russ Roth's Avatar
It will still work if you don't do that but the trans will go into limp mode and start in third gear. That's the only reason for the jumper. I think you have the correct wire and if you KNOW your ground is good the only other thing I can think of is a poor connection somewhere.
I had a crimp connection on the low beam on my '67 PW that suddenly didn't pass current. It was under the hood and when I was checking why my low beams were not working I saw a little spark from the connection. Tightened her up with the crimper again and she work fine. Had worked for about six years prior to this with no trouble at all. Good luck. HTH.
Old 01-05-2008 | 04:10 PM
chainzaw's Avatar
Just for kicks and grins try a different ground.
Old 01-05-2008 | 06:36 PM
MikeR's Avatar
Did you make your connection on the driver side wire harness, or the passenger side wire harness. Do it at the passenger side, and make sure you pull the trans relay and install the jumper.
Old 01-06-2008 | 01:27 PM
Mykey's Avatar
ok i've moved my ground made sure there is power from the connection from the computer on the passanger side made sure the jumper wire is connected good and still no go, has anyone ever had this problem before that yall know of.
Old 01-06-2008 | 05:40 PM
Russ Roth's Avatar
Will the computer lock it up?
Old 01-06-2008 | 09:03 PM
Mykey's Avatar
no it does not lock at all.
Old 01-07-2008 | 12:53 AM
Russ Roth's Avatar
You have a problem somewhere else then. PM sent.
Old 03-15-2008 | 12:44 AM
aautio1004's Avatar
What ended up being the problem....cuz I think I may be dealing with the same issue on my 01 with my install of the mystery switch
cowboykilla235
02-17-2013 04:02 PM
hoot
03-14-2011 05:43 AM
SPLnut
12-31-2007 12:27 PM
NHDiesel
08-20-2005 07:01 PM
Cummins4Life
04-14-2005 12:55 PM
