need gauges
Re:need gauges
Isspro are good gauges and autometer are good gauges.Shop around and find the best deal.Check out www.wildcatdiesel.com He is a straight shooter.I've dealt with him several different times and he gives it to you straight.His name is Pushrod on here.Pm him or call him.
Re:need gauges
DiPrico are highly rated as well.....Im partial to the Isspro EV (enhanced visibility) series....[they have white face marine guages as well].
Re:need gauges
I went with the "X" Monitor.
Easy to install, easy to read display, you can set trans, pyro, turbo alarm and the display will flash when that setting is reached. Trans temp is tapped into the wire from the factory sensor at the JTEC controller.
Administrator / Scooter Bum
Re:need gauges
[quote author=jrs_dodge_diesel link=board=4;threadid=22908;start=0#msg214922 date=1069956092]
Nice guages Shovelhead. Where are those mounted specifically? Middle of the dash maybe?
[/quote]
Yup ;D
[/quote]
Yup ;D
Re:need gauges
Even if Rod isn't at his desk, leave him a message with what kind of truck, what you're looking for, and your return phone number.
Rod ALWAYS calls back.
Re:need gauges
I've got a RodsPod for my gauges. And I like it ;D
I wouldn't have wanted an A-pillar, with the pod and a little bit of paint to match you can make that stuff look like stock.
AlpineRAM
AlpineRAM
