my buddys 24 valve is ideling high cant figer out why
could it be the high idle feature? what the temp outside? the high idle should disable when you start to move or step on the brake pedal. If its aways idled high not just when its cold ck the simple stuff first such as floor mat against the pedal etc. i work in a *********** and you wouldnt believe how often we see this on cars and trucks in the winter.
My truck would idle normal, then a little higher, then even higher, upwards around 1200 rpm. This was when the weather was warm and working the throttle did not fix it. I ended replacing the TPS and all is good.
Joe
Joe
highwayrepair
05-05-2006 08:03 PM
