Moving fuel pressure
My fuel pressure has been moving from 16psi to 8 or 9, when it drops I can give it more pedal and it will rise up to 16 again. I changed the fuel filter and drove it for a few days and it continued. So... I put in a new injection pump (blue chip diesel) I have been running on my old pump with multiple death codes for over 17,000 miles so I figured I would quit pushing my luck and buy one. My truck runs better however my fuel pressure is still moving! What causes this? Possible lift pump problem? Why does it raise again when I accelerate? Any ideas guys?
![Crazy!](https://www.dieseltruckresource.com/forums/images/smilies/crazy.gif)
mine did the same thing for a couple weeks. It has now moved on to the next stage of LP death in which it runs at about 5-7psi all day, until randomly it decides to wake up and run at 13-14... but even when it is actually running, it is real weak. the slightest bit of throttle can really pull it down.
to confirm it was the lift pump, once while it was running low like that, I shut it down and bumped the starter. nothing. again and nothing. third time was a charm and the LP started to run.
I already ordered a FASS.
dodgeguy71
17
01-19-2012 12:52 AM
LanceD
10-09-2006 04:49 PM
