Mind of its own!
Mind of its own!
Between 1500 and 1900 the RPM's fluctuate even though throttle is in one position. It seems to do this worse when the engine is cold and it is cold outside. Any suggestions would be nice thank you, this problem is occurring on my 5 speed
No its not that, there is like a dead spot in the throttle then you push the pedal a little further and it gets past it and its fine. Its just weird and hard to explain.
my first lift pump failure had those symptoms, like a bad accelerator pump on an older gasoline engine
NorKal12valve
05-08-2007 08:42 PM
