MAP sensor specs?
Old 09-17-2008 | 09:08 PM
The Doctor's Avatar
MAP sensor specs?
I just got a P0234 code today. I was looking around and found a bad MAP sensor could trigger this code without setting one for the actual MAP. Does anyone know what the ohm specs are and which pins to check them on? Any help would be great!
Old 09-17-2008 | 09:17 PM
BigIron70's Avatar
Cummins Guru
Hope this helps
Old 09-17-2008 | 10:22 PM
The Doctor's Avatar
Thanks for the help but I do not have access to a DRB and I was hoping I could find an actuall ohm spec. Maybe I am not able to check it this way and can only do it with a scan tool. Thanks for the help. Every little bit helps.
scottboy69358
07-04-2013 02:05 AM
Moobesor
02-23-2008 09:57 AM
kkyle69
07-07-2007 12:33 PM
Gene007
0
02-26-2006 04:31 PM
Booost Almighty
01-01-2006 01:41 PM
Quick Reply: MAP sensor specs?
